| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 11 Junior Member | | Junior Member Joined: Jan 2007 Posts: 11 | I’m starting the restoration on my 1968 Chevrolet ½ Ton and there is some technical information that I still have not been able to secure - through all the sources on line or publications that I have purchased and was hoping someone could help me.
A. On my VIN Tag underneath the VIN number is a stamped DD – anyone know what it means?
B. I’ve still have the production number of my truck on the firewall (it cross references with the same number located on the Seat frame and the printed circuit of the gauge cluster – how was the number on the firewall applied, grease pencil, paint?
Would appreciate any feedback that you could provide.
Thanks Larry Hull Ottawa, Canada.
None
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The markings on the firewalls of my 64s(all built in St Louis)is definately a paint. Brian | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Same as my 51 3600 built in St. Louis, written with white paint.
~Jim
| | | | | Joined: Jan 2007 Posts: 11 Junior Member | | Junior Member Joined: Jan 2007 Posts: 11 | Thanks guys - mine was manufactured in Baltimore. It sure looks like paint and thats what I will use.
Larry Hull
None
