6 members (UtahYork, Mr Crosswrench, RLB, 1955 1 Series, 55shaker, 1 invisible), 88 guests, and 1 robot.
Topics128,132
Posts1,056,391
Members48,441
#229815 03/20/2007 3:03 PM
Junior Member
Junior Member
DOES ANYONE KNOW IF I CAN CONVERT MY 67 PICKUP GRILL TO A 71 GRILL WITHOUT REPLACING HOOD AND FENDERS? THANKS
#229816 03/29/2007 2:29 PM
If i am not mistaken, you should be able to convert between 67-72 with very little design problems. Be prepared to modify where the holes are to attach the grill but the rough frame work and rad supports are very nearly identical.
Let me know how you do...i am working on a 67 chevy panel truck.
To restore an old truck is the work of a man...to restore a man is the work of God.
#229817 03/29/2007 5:52 PM
you would have to fabricate a center egg-crate piece; that is, about the onl way i see it possible, is to cut out the middle bar (where the bowtie goes on the '67-'68 grill) and then add in your center piece of choice.
otherwise, as far as just bolting the '71 grill on; nope. the '69 and up fenders have a lip on them for the aluminum grill surround to go over.
maybe GMC fenders? as they're the same shape as the '67-'68 fenders, but have the lip for the aluminum surround?
i dunno. i have no experience with GMCs.
best of luck.
.later days.
.sam.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
