0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#229577 03/17/2007 8:26 PM
I am having trouble with my steering It's difficult to turn standing still. It might just be my mind or my age. I checked the lube in the stearing box It seems low and it not a fluid but more like a heavy grease. I have oversize radial tires on my truck. I saw one post where someone used lucas oil additive in his box i don't know if he was kidding or not he said it steered like power steering any suggestion here.... Peter. Like i say it might be my age but it sure is tight to steer....
#229578 03/17/2007 8:37 PM
A bigger footprint and "armstrong" steering will make it hard to turn anyway. If the arms don't pull it you'll just have to learn to steer while rolling a bit, worked wonders for me :o , but I had to learn to think ahead a bit while parking.
#229579 03/17/2007 9:08 PM
I know what you mean armstrong steering...
#229580 03/17/2007 9:44 PM
Run the highest permissible tire pressure in the front. When you grease your kingpins, take the weight off the tires with a jack. That will get more lubricant where it counts, at the bottom.
1951 3800
-hotshoe
#229581 03/18/2007 7:43 PM
Power assist steering might help- Basically its a hydraulic piston attached to the centerlink which give you a little boost when you start turning the steering wheel in either direction. They are a bit spendy, but a few people have posted on this site saying they love it.
