| | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I am having trouble with my steering It's difficult to turn standing still. It might just be my mind or my age. I checked the lube in the stearing box It seems low and it not a fluid but more like a heavy grease. I have oversize radial tires on my truck. I saw one post where someone used lucas oil additive in his box i don't know if he was kidding or not he said it steered like power steering any suggestion here.... Peter. Like i say it might be my age but it sure is tight to steer.... | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | A bigger footprint and "armstrong" steering will make it hard to turn anyway. If the arms don't pull it you'll just have to learn to steer while rolling a bit, worked wonders for me :o , but I had to learn to think ahead a bit while parking. | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I know what you mean armstrong steering... | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Run the highest permissible tire pressure in the front. When you grease your kingpins, take the weight off the tires with a jack. That will get more lubricant where it counts, at the bottom. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Power assist steering might help- Basically its a hydraulic piston attached to the centerlink which give you a little boost when you start turning the steering wheel in either direction. They are a bit spendy, but a few people have posted on this site saying they love it.
