7 members (Gdads51, 55shaker, 3B, Joe H, Cletus1950, carbking, moparguy),
402
Mod | | | Forums66 Topics128,162 Posts1,057,047 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | I was woundering who may have a Chevy AD around the year 51 that has not been restored. I would like to get some pictures on what the body bolts looked like that hold the front fenders and the radiator to see if mine are the origanals. I have been to junk yards and saw diffrent bolts used. | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | PM brjr51 here on the Stovebolt. I think he can help you, as he's an expert on this subject. | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | david, i have an original unrestored 1950 3/4 ton. pretty sure they bolted up the same as the 51 so let me know what you specifically need pictures of and i'll take some and e-mail them to you. [email protected] | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | The ones I've come across have had 4 different foundry markings on the head. The most common are the letters TR or just R. No other marks, just the letters. Another has the letters WB on a slightly indented head, sorta looks like WB surrounded by a raised circle around the outer part of the head. And a fourth had no markings at all, probably just made its way through the forming process without getting stamped. Then there are the #14 sheet metal screws, such as on the lower grill to splashpan and a couple of places on the hood latch to grill panel. They are just indented head. It's common to have a mismatch here and there, when the assembly line worker was pulling bolts, he wasn't concerned if the markings were the same.When a bolt bin was getting low, they'd probably just call material control and dump another box full in. Bob | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | brjr51 I sent you a e-mail with pictures are they the type that your saying that has the rounded raised circle | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | p.j. Most of what im looking for would be eng. compartment. front fenders to inner fenders,radiator,The hood latch plate. I have had bolts holding mine on. But I have sean sloted screws and clutch head. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | David, The hood latch plate should be clutchhead. I sent you some photos of bolts.
Bob | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Originally posted by David Sr: p.j. Most of what im looking for would be eng. compartment. front fenders to inner fenders,radiator,The hood latch plate. I have had bolts holding mine on. But I have sean sloted screws and clutch head. I have seen both phillips and clutch head screws used. It depends on which plant built them. GMC'S used mostly clutch heads, although that is argued about too. I just tore apart a 51 Suburban that had a mixed lot of screws and it was original. | | |
