5 members (RoadsScholar, dt235sd, JoergK., carbking, 1 invisible), 359 guests, and 5 robots.
Topics128,164
Posts1,057,079
Members48,463
I was woundering who may have a Chevy AD around the year 51 that has not been restored. I would like to get some pictures on what the body bolts looked like that hold the front fenders and the radiator to see if mine are the origanals. I have been to junk yards and saw diffrent bolts used.
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
PM brjr51 here on the Stovebolt. I think he can help you, as he's an expert on this subject.
To be long remembered as he's cruising in
The Passing Lane
david,
i have an original unrestored 1950 3/4 ton. pretty sure they bolted up the same as the 51 so let me know what you specifically need pictures of and i'll take some and e-mail them to you.
[email protected]
The ones I've come across have had 4 different foundry markings on the head. The most common are the letters TR or just R. No other marks, just the letters. Another has the letters WB on a slightly indented head, sorta looks like WB surrounded by a raised circle around the outer part of the head. And a fourth had no markings at all, probably just made its way through the forming process without getting stamped.
Then there are the #14 sheet metal screws, such as on the lower grill to splashpan and a couple of places on the hood latch to grill panel. They are just indented head.
It's common to have a mismatch here and there, when the assembly line worker was pulling bolts, he wasn't concerned if the markings were the same.When a bolt bin was getting low, they'd probably just call material control and dump another box full in.
Bob
brjr51 I sent you a e-mail with pictures are they the type that your saying that has the rounded raised circle
David
p.j. Most of what im looking for would be eng. compartment. front fenders to inner fenders,radiator,The hood latch plate. I have had bolts holding mine on. But I have sean sloted screws and clutch head.
David
David,
The hood latch plate should be clutchhead. I sent you some photos of bolts.
Bob
Quote
I have seen both phillips and clutch head screws used. It depends on which plant built them. GMC'S used mostly clutch heads, although that is argued about too. I just tore apart a 51 Suburban that had a mixed lot of screws and it was original.
