11 members (frogfarmer, Scott, Wayne67vert, cmayna, 48jim1ton, Wally / Montana, gswbbc, Gdads51, panel fan, FAST55, 1 invisible),
112
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 12 Junior Member | | Junior Member Joined: Jan 2007 Posts: 12 | I am sure this is dumb but my only experience is cars and bikes. I have a 72 GMC. 1/2 ton. It had no engine so i used a spare 350 I had around. I have never seen motor mounts like these though. the horns from the frame have a single hole in them on the top. my experience has been with a a different style motor mount. are these "clamshell mounts" when I Google mounts I can only find the plate that mounts to the motor. I have that part handled. maybe I don't know the correct name. Anyhow. i need to find the frame horn side of the motor mounts. what are they called, where can i find them. Thanks Greg | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I think your talking about "motor mount perches" if I understand you is the term used. There what the mounts sit on.Good luck and hope you find what your looking for. Bob T | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have the brackets on the frame all you need are the motor mounts for that application, available at any parts store. The mounts bolt to the block with short 3/8 USS bolts & a 5/8 USS bolt comes up from the bottom of the perch. I always cut or drill the hole in the perch larger. Sometimes the hole doesn,t quite line up & can cause some choice words. Use a large thick flat washer under the head of the bolt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 12 Junior Member | | Junior Member Joined: Jan 2007 Posts: 12 | | | | | | Joined: Jan 2007 Posts: 12 Junior Member | | Junior Member Joined: Jan 2007 Posts: 12 | alright then,I see why you might want to hog out the bolt holes on the frame horns. I think I 'll take a break. so far an engine hoist, come along and pry bar aren't getting that second mount in. By the by, if anyone else is paying attention my particular truck took 7/16 bolts for the motor mount | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Just so all the bases are covered. Are both mounts the same distance from the firewall? GM does have one exception and that's the 292 six, the passenger side is about an 1 1/2 forward of the drivers side. 292s arn't usually found in 1/2 tons, but after 34 years who knows. My two bits.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
