7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59), 82 guests, and 3 robots.
Topics128,031
Posts1,055,435
Members48,422
#229383 03/15/2007 7:00 AM
Junior Member
Junior Member
I am sure this is dumb but my only experience is cars and bikes. I have a 72 GMC. 1/2 ton. It had no engine so i used a spare 350 I had around. I have never seen motor mounts like these though. the horns from the frame have a single hole in them on the top. my experience has been with a a different style motor mount. are these "clamshell mounts" when I Google mounts I can only find the plate that mounts to the motor. I have that part handled. maybe I don't know the correct name. Anyhow. i need to find the frame horn side of the motor mounts. what are they called, where can i find them.
Greg
#229384 03/15/2007 3:04 PM
I think your talking about "motor mount perches"
if I understand you is the term used. There what the mounts sit on.Good luck and hope you find what your looking for. Bob T
#229385 03/15/2007 9:07 PM
Riding in the Passing Lane
If you have the brackets on the frame all you need are the motor mounts for that application, available at any parts store. The mounts bolt to the block with short 3/8 USS bolts & a 5/8 USS bolt comes up from the bottom of the perch. I always cut or drill the hole in the perch larger. Sometimes the hole doesn,t quite line up & can cause some choice words. Use a large thick flat washer under the head of the bolt.
1972 Chevy c10 Cheyenne Super
#229386 03/18/2007 3:25 AM
Junior Member
Junior Member
thanks
Greg
#229387 03/19/2007 1:41 AM
Junior Member
Junior Member
alright then,I see why you might want to hog out the bolt holes on the frame horns. I think I 'll take a break. so far an engine hoist, come along and pry bar aren't getting that second mount in. By the by, if anyone else is paying attention my particular truck took 7/16 bolts for the motor mount
#229388 03/19/2007 2:03 AM
Just so all the bases are covered. Are both mounts the same distance from the firewall? GM does have one exception and that's the 292 six, the passenger side is about an 1 1/2 forward of the drivers side. 292s arn't usually found in 1/2 tons, but after 34 years who knows. My two bits.
Larry
I don't own a vehicle that isn't old enough to drink.
