2 members (crenwelge, dt235sd),
136
Mod | | | Forums66 Topics128,290 Posts1,058,557 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | The truck runs much better with the Carter YF on there! A buddy came over with some sandblasting gear, so we dressed up the Valve cover a bit. http://i62.photobucket.com/albums/h93/Halsey_Motors/EngineCompartment1.jpg Hope that works. It's not too big. In a few minutes I'm going to drop the bumper and start pulling rotten bed wood. That should keep me out of trouble for the remainder of the weekend! CJ | | | | | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Looking pretty good...Where did you buy your Carter YF from? | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | I ordered it from Summit. Couldn't find anything in good shape that had linkages that were close locally, so ordered one of their "Rebuilds." A little tweaking of the idle and mixture was all it took. CJ | | | | | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Do you have a part number for that Carter YF | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | HLY-64-2025
It specs for the '67 250 inch engine with Manual choke.
They have a few different ones to choose from. Just search for for the correct carb for your application on their site.
CJ | | | | | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Another question what size motor is that? | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | | | |
