2 members (Wally / Montana, TooMany2count), 32 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#229030 03/09/2007 10:11 PM
Junior Member
Junior Member
When I purchased my 41 pu it had no wood in the bed and no wood blocks under the cross sills.I am installing a new rear suspension and need to know how much clearance there is between the top of the frame over the rearend and the wood.
Thanks in advance.
#229031 03/10/2007 12:28 AM
The wood sits 1/2 inch above the frame with new blocks and rubber pads at the high point above the rear end. When I took it apart, I am thinking the wood almost touched the frame.
#229032 03/10/2007 2:49 AM
Junior Member
Junior Member
Thanks for the info. I was hopeing the gap was larger so I could have more room for suspension components without putting small tubs.
#229033 03/10/2007 5:29 PM
41,
Are you going stock or rod? If you go with your stock bed, the sides don't hang over the frame so tire clearance should not be an issue.
Check out some of my latest webshots and you should be able to see how the tires and bed line up.
If not, let me know and I will take some more shots for you and post em.
