| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Are there any differences between a 292 block from 1966 and one from 1969? Not so much inner workings, but things like mount pads for alternator, clutch, motor mounts, things like that. Thanks. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Should be the same...There was 1 year they used a 1 piece intake/exhaust manifold which was a piece of junk, but other than that they should be the same.. my interchange only goes to 65, but shows same block. My factory parts catalog shows same from 63-72, so you should be ok...
Geoff
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | This vendor shows the same 4 block casting numbers for the 63-66 292 and the 67-72 292. http://www.butlers-a1.com/chevym.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are near the same. The early models had 7/16 holes in the crank for the flywheel same as the smaller 6,s & v-8,s. The latter ones had 1/2 in. bolts. You can drill the small hole flywheel out to use the bigger bolts. The early ones had the temp sender in the therm. housing & latter ones had an opining in the head. 73 up went to small belt pulleys & damper. 1 ton & smaller had 2 in. exhaust pipe outlet like the smaller engines & 1 1/2 ton up had 2 1/2 in. outlet. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Thanks. I have just bought a block with casting number 3921970 to put into a '66 C-10. From what I saw online, that casting ran from 63-76. My suffix code is RE, which another website told me was from 1969. Sounds like none of this will present a problem as I attempt to piece the various components onto it and drop it in. Would appreciate if anyone has other data regarding this casting number and/or suffix code. | | | | | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Mr Wrenchbender, Sir,
So if I wanted this to be correct for 1966 factory correct, I should obtain a therm house that has a temp sender port? Another question along that line, would a '66 have had the cooling sytem bypass? And does that hose come out of the therm housing or the water neck? Lastly, I have seen "vertical" and "horizontal" water necks for these engines. Which came with which? THANKS! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most therm housings will have the port for a gauge. It will have a pipe plug in it if it wasn,t used. They all have bypass hoses that go from the water pump to the therm. housing. The 73 up used a 5/8 hose & the earlier ones used a 1 in. They are available from any parts store. The water outlet direction depends on the application. They interchange with v-8,s. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
