4 members (69 coupe, 68ironhead, Maybellene, 1 invisible), 65 guests, and 6 robots.
Topics128,064
Posts1,055,861
Members48,428
#22829 10/07/2003 12:04 PM
I
I Offline
Is there anyway to go to mono leaf springs without lowering the truck? I guess a couple of inches would be okay but I want to stay very close to stock height.
#22830 10/07/2003 5:03 PM
Why use monoleafs if you don't want to lower? New springs are actually cheaper than monoleafs.
54 3100 with 235
62 flatbed dump C60 with 261
#22831 10/07/2003 7:59 PM
I
I Offline
The reason I was considering this is because I have read that they provide a better ride and handling. I believe this is because of the lack of friction between the leaves on a standard leaf spring set up. I know that liberal greasing or teflon strips between the springs can greatly reduce friction and provide a better ride. Just seeing what you guys thought.
#22832 10/07/2003 9:16 PM
Get some good shocks and put on a stabilizer with stock springs should get you pretty close. The only other difference would be that the mono's have lower center of gravity.
54 3100 with 235
