| | | Forums66 Topics128,051 Posts1,055,734 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22829 10/07/2003 12:04 PM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | Is there anyway to go to mono leaf springs without lowering the truck? I guess a couple of inches would be okay but I want to stay very close to stock height. | | |
#22830 10/07/2003 5:03 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Why use monoleafs if you don't want to lower? New springs are actually cheaper than monoleafs.
54 3100 with 235 62 flatbed dump C60 with 261
#22831 10/07/2003 7:59 PM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | The reason I was considering this is because I have read that they provide a better ride and handling. I believe this is because of the lack of friction between the leaves on a standard leaf spring set up. I know that liberal greasing or teflon strips between the springs can greatly reduce friction and provide a better ride. Just seeing what you guys thought. | | |
#22832 10/07/2003 9:16 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Get some good shocks and put on a stabilizer with stock springs should get you pretty close. The only other difference would be that the mono's have lower center of gravity.
