1 members (Hotrod Lincoln), 76 guests, and 8 robots.
Topics128,021
Posts1,055,352
Members48,420
#227990 02/26/2007 8:49 PM
Junior Member
Junior Member
I have a technical question that I hope someone can help me with:
I have a 1968 Chevy, Shortbox Stepside, with a 250 C.I. 6 Cyl., 3-Speed. The VIN numbers support the 250/3 speed..
This vehicle was originally from Georgia and brought to Canada 10 years ago.
The issue is – the original 250 motor was replaced with a Canadian motor, verified by the serial numbers. I want to procure an original U.S. block for my re-build and have conflicting information on what the “block numbers” should be.
I have an original 1968 Chevrolet Truck Chassis Service Manual and it states the following for block identification.
Engine Number:
F - Manufacturing Plant (F-Flint, T- Tonawanda)
12 - Month of manufacture (December)
10 - Day of manufacture (tenth)
FA - Transmission and engine type
However, according to American Classic Truck Parts – “Truck VIN decoder” for the 1968 model, the numbers are one of the following: ( TA / TC or TD )
1/2-Ton TA 6 250 155 8.5:1 1-bbl Manual
1/2-Ton TC 6 250 155 8.5:1 1-bbl Manual
1/2-Ton TD 6 250 155 8.5:1 1-bbl Manual
If the “T” stands for “Tonawanda”, what does the following number represent?
The Transmission coding is as follows – the “W, K or S, do not correspond with the Service Manual?
W N/A 3,4 speed Warner Gear
K N/A 3 Speed McKinnon
S N/A 3 Speed Saginaw
Can anybody give me some feed back?
Larry Hull,
Ottawa, Canada.
None
#227991 02/26/2007 9:02 PM
Welcome to the Bolt,,Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#227992 02/26/2007 9:08 PM
Ditto, Welcome to the Bolt!
Brian
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
