| | | Forums66 Topics128,118 Posts1,056,302 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Hi All, Does anyone know what the differences between a 55-59 Chevy or GMC frame, 1/2 vs 3/4 ton for the long wheelbase? I have a 56 GMC 1/2 ton, 8 foot bed frame from a parts truck in decent shape and a 56 Chevy 3/4 ton project truck frame that some torch-happy person had their way with.  I was think about swapping them out. Thanks
JC in KC "The future will be better tomorrow." Dan Quayle 1965 Chevy C10 Long Fleetside
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | for the same year I think you'll find some differences Chev vs GMC around the front crossmember, as the GMC had a different engine mount setup ... between 1/2 and 3/4 there will be different springing, so maybe different mount points
if you've got both at hand, just put'em side by each and start comparing, with your plans in mind re winding up with a 1/2 or 3/4 and what engine you'll use
Bill | | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Thanks. Right now they are at 2 different storage yards. Most of the parts I've been collecting are for the 3/4 ton and I have a rebuilt stock 235/4 speed driveline out of a 58 chevy PU.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might hafta make some changes to the GMC frame to mount that 235, but should be do-able with stuff from the Chevy
Bill | | |
