0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#227929 02/23/2007 5:56 AM
Apprentice
Apprentice
Recently I was browsing around and read something about "Gibbs Oil" or something that sounded like that. The Gentleman who was using this product used it as a penetrent as well as a lubricant. Another interesting thing he used it for was what he called "Priming over rust" before actual primer and paint. He said the rust never came back. Has anyone heard of this kind of oil and what have you used it for? Also, is it available in Canada, online etc?
#227930 02/23/2007 11:52 AM
#227931 02/23/2007 1:47 PM
Never seen it before but it sounds like a viable product. Noticed a major difference in price between suppliers. "The Thing Shop" was advertising it at $8.95 a can, so being a sucker for anything that will work well on guns and cars, guess I'll try the product for myself.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#227932 02/23/2007 2:23 PM
I'm going to give it a try also! smile
#227933 02/23/2007 6:52 PM
I found this supplier ... and wound up building his web site!
grin
Check it out: GetGIBBS.com
PS - I tried GIBBS and was amazed! It's the only thing that stopped my fan belts from squeeling ... you can definitely use it instead of primer (my nephew paints cars and couldn't believe it until he tried it) ... it not only prevents rust but it actually eats rust ... and if you have any stainless steel appliances, you know about fingerprints that can't be removed -- GIBBS removes them forever. Way cool.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#227934 02/23/2007 9:47 PM
This stuff looks like quite the all purpose product. To those of you who have used this stuff; can I spray it into the cylinders of my engine that has not turned over in 25 years and unfreeze the motor? If so, I will get some & try it there and also try it on some of the other rusty parts on my 57 project truck.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#227935 02/23/2007 9:53 PM
Hey, Alan.
Yes, you can! It's a good carb' cleaner, too!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#227936 02/23/2007 9:59 PM
O.K. my friend. Since I am getting it, I am going to try it on several things. If you have used it and say it is good stuff, I know that your word is good enough for me.
#227937 02/23/2007 11:39 PM
Trust me ... there's nothing like it.
Another experience I had with GIBBS was the push-buttons on my door handles. Another lesson in aftermarket garbage, they keep rusting up on me. I polished them with chrome polish after getting the rust off and it would just keep coming back. This is how I discovered GIBBS ... I was telling a Harley enthusiast about the rust and he just looked at me and said, "GIBBS."
I cleaned the rust off again and applied GIBBS to the buttons ... a few days later I did it again. That was last Fall and I haven't seen any rust since!
You can read more testimonials here:
http://getgibbs.com/testimonials.php
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#227938 02/26/2007 3:39 AM
Former Workshop Owner
New to me, going to check it out.
Thanks for the tip
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#227939 02/26/2007 4:14 AM
Something I don't understand? On the website it says you can paint over it, but if you read his paragraph about painting over it, it says in effect that you remove it with whatever surface cleaner your paint manufacturer reccomends. How's that painting over it if you have to remove it first? It also says it will penetrate gaps as small as one micron. So will most all liquids, especially those thinner than water.
Harold Wilson
41 Chevy 3/4 Ton
#227940 02/26/2007 4:34 AM
Before painting over it, you use the surface cleaner ... but by then, the GIBBS has penetrated the metal. You're only removing the surface residue.
PS - This stuff has been around since the 60s ... it was invented by a guy who worked at Harley Davidson and had a chemical background.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
