0 members (),
88
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Spent 40 minutes tonight removing the speedometer from the back side of the dash, installed a new speedometer needle and replaced the unit back into the dash. 3 screws, the speedometer cable and a snap in high beam light. That was it !!
Wonder if it is even possible with a vehicle newer than the 60s | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I think to get to the speedo cable on my 81 Malibu I have to remove the instrument panel which I can only do if I drop the steering column. I could go from the transmission but most of the problem is in the speedo head. | | | | | Joined: Feb 2007 Posts: 5 Junior Member | | Junior Member Joined: Feb 2007 Posts: 5 | I did one in my 1997 GMC and it took over 1 hour | | |
