| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 7 Junior Member | | Junior Member Joined: Jan 2007 Posts: 7 | Does anyone know what vehicle is a good donor for a steering column for my 53 Chevy pickup? I might be able to get my hands on a 80 Camaro column. Would that work? Just in case I can't get do you have other Ideas. I am going with the MII IFS power steering, putting in a chevy small block and a 700r4. | | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | One from a Camero will work fine. I used one from a 83 and used the brake pedal/booster assembly from a 84 s-10 to tie it all together. | | | | | Joined: Jan 2007 Posts: 7 Junior Member | | Junior Member Joined: Jan 2007 Posts: 7 | Did you have any problems setting up the s-10 brake pedal? I was told to go with an aftermarket part because the brake pedal was hard to rig up. | | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | Originally posted by 1stTime53: Did you have any problems setting up the s-10 brake pedal? I was told to go with an aftermarket part because the brake pedal was hard to rig up. It was one of the easiest to do. Start to finish was about an hour. | | |
