1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22771 06/30/2004 7:37 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Where's the top fill plug? I have the original 4 speed transmission and I wanna top up the gear lube. I've been filling it from the top tower with the stick removed but there's gotta be an easier way. Plus I don't know if I have the proper level. Silly question isn't it? Maybe I'm not looking hard enough. :rolleyes: | | |
#22772 06/30/2004 10:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Got to be a square pipe plug on the side of the transmission. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#22773 07/01/2004 12:19 AM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Remove the square pipe plug from the passenger's side of the trans, and fill it just level with the plug hole. DON'T remove the bolt on the driver's side, it's the pivot for the reverse gear linkage, and you'll have to pull the top of the trans to reinstall it in the right place! Jerry
#22774 07/01/2004 2:46 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Thanks alot. I found it, I wasn't looking hard enough. It was almost right against the battery box. Boy was I low on lube!!  | | |
#22775 07/04/2004 5:01 AM | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Steppenwood, did filling the transmission make any difference in its operation? Jacques
Union, Justice and Confidence
#22776 07/04/2004 5:59 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | It made a HUGE difference. It's quieter and smoother. I was have trouble getting into first or reverse gear even at a dead stop. john. | | |
