3 members (Nick in Manitou, TexasA&M48Truck, Hotrod Lincoln), 191 guests, and 2 robots.
Topics128,082
Posts1,055,964
Members48,430
#22771 06/30/2004 7:37 PM
Where's the top fill plug? I have the original 4 speed transmission and I wanna top up the gear lube. I've been filling it from the top tower with the stick removed but there's gotta be an easier way. Plus I don't know if I have the proper level. Silly question isn't it? Maybe I'm not looking hard enough. :rolleyes:
#22772 06/30/2004 10:12 PM
Riding in the Passing Lane
Got to be a square pipe plug on the side of
the transmission.
1972 Chevy c10 Cheyenne Super
#22773 07/01/2004 12:19 AM
H Online: Content
Remove the square pipe plug from the passenger's side of the trans, and fill it just level with the plug hole. DON'T remove the bolt on the driver's side, it's the pivot for the reverse gear linkage, and you'll have to pull the top of the trans to reinstall it in the right place!
#22774 07/01/2004 2:46 AM
Thanks alot. I found it, I wasn't looking hard enough. It was almost right against the battery box. Boy was I low on lube!! eek
#22775 07/04/2004 5:01 AM
Steppenwood, did filling the transmission make any difference in its operation?
Jacques
Union, Justice and Confidence
#22776 07/04/2004 5:59 AM
It made a HUGE difference. It's quieter and smoother. I was have trouble getting into first or reverse gear even at a dead stop. john.
