Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (FAST55, JW51, Ponchogl, Hanks custodian), 37 guests, and 3 robots.
Topics128,009
Posts1,055,297
Members48,419
#227680 02/20/2007 4:18 AM
I have a 65 c10 that i am restoring. I have found a 64 cab.My question is will it bolt right up,or are there any mods that need to be made? anyone got an idea?
"you can't fix stupid"
#227681 02/20/2007 4:20 AM
they're identical
#227682 02/21/2007 4:20 AM
thank you 66. I was just concerned as the 64 I may get has the removabe hup.Any ideas what that is/was for?
#227683 02/21/2007 2:56 PM
The 4 speed & 4x4 trucks had the higher removable trans hump. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#227684 02/23/2007 4:45 AM
gotta be the old 4 spd then. Pulled up the vin, and it lists as a 2wd. thanks again for all the info. .........
#227685 02/23/2007 5:12 AM
i went to the local wrecking yard the other day and they had three early 60's chevy trucks in the yard, not much left tpp them and sadly to say the fella who operated the fork lift did not take it easy on the cabs, two of the trucks roofs were pulled almost off the cab, if anyone wants anything just let me know and i will check it out and see if the wrecks have a good part...
