4 members (Gdads51, Hanks custodian, MickeyP, homer52), 114 guests, and 6 robots.
Topics128,089
Posts1,056,137
Members48,435
Apprentice
Apprentice
1 Offline
how do ya fix droopy door handles? My door handles don't sit right. Is there an easy fix or do I need new assemblies.
http://i22.photobucket.com/albums/b350/stevehsd/spotlight-1.jpg
That is caused by a faulty spring inside the mechanism. I have seen references to a replacement spring. Personally I am installing NOS mechanisms. I have seen comments that the repopped assemblies are not as good as the originals but I have no experience with them.
1951 1 Ton Completed
I put new repop door mechanisms in mine and the door handles still droop.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
Once i seen in a hot rod mag where they bend the rod are what ever the handle is on so that the handle would set right .....Never did it my self have push button type handles ,,,don't know if you could do that on that type even .
just a thought ....
:rolleyes:
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
Is the spring that is listed at the bottom of this page the part that you have replaced in an attempt to "level" the door handle?
new springs should take the droop out of that door handle...
Another quality post.
Real Trucks Rattle
viagra? grin
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
tclederman, that is the spring that needs replacing to fix droopy door handles. Takes alot of work to get it replaced since it is punched in the door hinge.
You may want to take a look at the Door Latch Spring at Jim Carter's. The description of PN DP133 states that it eliminates outside drooping handle. cool
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
Chevy Duty also sells this spring.
http://www.classicparts.com/prodinfo.asp?number=18-575
47-51
(1947-51) Door Latch Spring
Door Latch Spring
47-51
Quantity
Price: $4.95
Part # : 18-575
Year : 47-51
Ships:
Product Description
Large coil spring fits on door latch to prevent outside door handles from sagging.
You May also like
(1947-63) Door Latch Repair Clip
~Jim
Hi all,
Can anybody help me out with some proper instructions on how to properly access and reinstall this spring (part 18-575 from Classic Parts)? Is there an easily followed method? The droopy handle issue is such a common problem with these trucks, I would think that a nice, succinct tech tip would be a nice contribution for the site... hint hint. (I'll make you a deal: if you write the instructions, I'll take photos while I follow them grin )
Many thanks,
Nick
All fixed. See this link for details. In my case, replacing this spring (part 18-575 from Classic Parts) did the trick. Hope it works for others too.
