0 members (), 140 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#227461 02/18/2007 6:24 PM
I did a search and didnt find an answer to this question. Is swapping a granny 4-speed to a T5 a simple matter of unbolt/bolt in or does the driveshaft length need changed? Any other changes I would need to do? I have read about different splines on these trannys, which is the correct swap??
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
search T5 and T5 task force in this forum, the hi-po forum and driveline forum
T5 in task force
T5
nothing is "simple" grin the spline will be different, but can be adapted, not sure about the trans length re the driveshaft length, and you may need to add a trans support crossmember - part of why I prefer to stick to bolt in swaps ohwell
It's way more involved than a simple unbolt and bolt up.. and in many cases, the rear end has to be changed or re-geared to see any real benefit from a t5.
Riding in the Passing Lane
I,ve done 2 of them. It,s not a bolt in swap but pretty easy as swaps go. I think the end justifies it. There is a world of info on this websight in the tech tips & search the posts. Thats how I learned enough to do it. I take it you are working with a 58 or 59. The rear ends in either one sould work fine.
1972 Chevy c10 Cheyenne Super
