| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 12 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 12 | Can someone tell me or email me a picture of where the throttle cable from inside the cab hooks up to the carb. I see where the housing goes, but I dont see where the cable hooks to. Thanks. Curtis. | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 |
1953 Chevrolet 3100
| | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I just went through the same thing with my 1960. In my case the throttle cable attaches through the same bracket(mounted on the carburetor) that holds the choke cable. The choke cable sheath attaches horizontally, and the throttle sheath attaches vertically with the moveable wire extending down to the throttle below to another brass ball/set screw. This may not be true for the Carter carburetor . Sam | | | | | Joined: Nov 2006 Posts: 21 Junior Member | | Junior Member Joined: Nov 2006 Posts: 21 | I'm getting ready to put the throttle cable on my truck as well...I thought it attached down near the firewall where the throttle bracket attaches. There is an extra bracket there...Anyone know why?
I wouldn't recommend drugs, alcohol, and violence to anyone...but they've worked well for me.
| | | | | Joined: Nov 2006 Posts: 12 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 12 | Chris, Thats what I was thinking, but there is no brass ball set screw that came with the new throttle. I see where the linkage is for the foot (gas) throttle and I was thinking that it might go through a hole where a cotter pin is right now. When I got the truck, it had no throttle cable coming from the cab. kcwelshans, Look at Chris's picture, should set you straight. Send me a picture of the extra bracket attached, see if I can help out. Lived in Monterey for 4 years, Naval Post Graduate School. Thanks Guys, Again. Curtis. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That picture from Chris's truck shows a carb that is not from an AD truck. It has an automatic choke and the fuel inlet is in a different location than on an AD motor. | | |
