3 members (2-Ton, Mike B, 1 invisible),
69
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 6 Junior Member | | Junior Member Joined: May 2005 Posts: 6 | Hello all, I have a Borg Warner T5 Trans from a 1982 GMC pickup(S15), the sticker on top says 1352-598-047, can anyone tell me what the gear ratios are in this trans and would it be satisfactory behind a 235 motor and a 307 rearend?  I appreciate any information that anyone has...Thanks...oldred36  | | | | | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Looks like you still need the actual tag # try this | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | There have been many, many threads about T5 swaps and I seem to remember a number chart somewhere. Have you searched the Tech Tips on this site or did a search of the forums? You could also try the tech tips page on the inliners site. Good luck.
Professional Novice
| | | | | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | Tractorboy posted the link to the number chart.
As he says, the number doesn't match anything on the chart, nor does the chart show a t-5 for a 82 S-15. If I remember right, the correct number is stamped on a tag on the top of the tranny? (there are other numbers stamped on the gear box and tail housing)
Good luck Dave | | | | | Joined: Jan 2007 Posts: 7 Junior Member | | Junior Member Joined: Jan 2007 Posts: 7 | hi guys i heard a t-5 from 81-84 camero works ...im getting one soon and will look into it ....i want that overdrive..i have a saginaw 4-speed with a 57 3-55 rear...this is in my 48 with a 56 235 with a tom langdon carb setup with headers...a sweet ride..i have 79 truck power steering convertion steering is too light no rode feel kozy | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hi oldred36, Sent you some info through the site email. Hope it helps. Dave  | | | | | Joined: May 2005 Posts: 6 Junior Member | | Junior Member Joined: May 2005 Posts: 6 | Hey Guys, I finally found the tag on the T5 and it is; 1352-149 according to the charts its an 84-86 S10 w/ a 3.76 Ist gear ratio. Looks like it's in decent shape, little discoloration in the fluid but no meta :rolleyes: l chunks. Thanks for your help...oldred36 :rolleyes: | | |
