1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
#226541 02/06/2007 3:49 PM
I put a ignitor on the 350 in my El Camino about 10 years ago. It has been trouble free, but I wonder is it every going to quit. Anyone every have one fail? How long have they been known to work?
i love my dog's 1965 suburban.
yours will probably go tomorrow... get you a spare grin
Redryder pix
My Hotrod
My experience with Pertronix is not that good, I put the whole system, module, rotor, cap, wires & plugs in my 1992 GMC 350 and the module lasted 2 miles. Went (physically) to Pertronix in San Dimas and talked to their "expert", he gave me a new module that he personally tested in the lab, I installed it and lt lasted 3 miles. I put back the stock module that was from GM, original equipment that has 200,000 miles on it and it is fine again, go figure.
Z
Z Offline
heis are cheep,easy to install and work great.
I put one in my farm tractor 5 years ago ... still going strong.
(Also have a spare "just in case".)
What is it? Just a coil?
#226547 02/07/2007 11:02 PM
Quote
Pertronix Ignitor should last as long as any HEI distributor. It is a solid state device that will be affected by heat and current in combination with time. High heat and/or high current will reduce the amount of time until it fails. How long can it last? If it's like the POS ones F--d used in the late 80's through the 90's, the expected life is about 3 years, but it could conk out after a month. If your vehicle is a daily driver, I might get a little worried after ten years. Three possible precautions that I can think of. Cheapest (but not the most convenient or surest) would be to keep a set of points in the glove box to install if and when the ignitor module fails just to get you home. Cheaper would be to keep a spare Ignitor module in the glove box just in case; however, I don't think it would be good to store one in the glove box during the summer given the cab temperatures that are typical where I live, anyway. Relatively cheap (and useful in other instances, as well) would be a AAA membership for a tow if and when the truck breaks down.
58 Fleetside, 235, "The Old Buckin' Bronco"
#226548 02/07/2007 11:17 PM
I don't know about the Pertronix but solid state devices like ignition modules do not have a predicted lifetime in which they wear out. They do fail, probably very infrequently and in a random manner. Either there is something wrong with the product or the there is something wrong with the installation.
1951 1 Ton Completed
