1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Why is my oil breather cap spilling oil on to my valve cover?
Does it need cleaning and if so how? Or should I replace it? Also, when I stop the engine, vapor comes out of the oil breather cap. How much is normal?
The cap looks to be in good shape. This is on a 1960, 235 six. The engine runs great otherwise.
Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the lack of a PCV setup allows worn engines to put a bit of interior fuming out the breather, and the vapor when you shut it off is just hot, moist air rising .... if there's whiteish/brown crude built up on the inside of the cap and around it's spot in the cover, yer running the engine too cold, or "short tripping", and that will plug the filter material some ... not much to be done really, but you could clean the cap by sloshing it out with solvent ... and you could move to a warmer, drier climate Bill | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Thanks for the info.
I will try some kersone as solvent to clean the cap. I believe that's what was used back then wasn't it?
Thanks again.
Jeff ( Iron Clad ) | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Funny, my 61 does the exact same thing. She puffs a little cloud of smoke from the brather cap when I shut her down. I just assumed it was normal for a 45 year old truck to do this. It might need a new breather cap, but whats the point in changing it when it will just fill up again with oil. Anyways, it made me laugh to hear about someone with the same quirky motor thing.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2007 Posts: 30 New Guy | | New Guy Joined: Jan 2007 Posts: 30 | Ja mine does the same. Was concerned but it is normal it seems. Ive got a new cap and it still smokes after a shutdown, but does not get clogged. The fumes smell of hot oil so I presume my engine is a bit long in the tooth! | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm running a 350sbc but under my oil breather cap, in the valve cover, there's a 1-inch strip of steel that blocks most of the hole. It's a bit of a pain when I'm putting oil in; I have to go slow ... but they say it's there to keep oil from pumping out.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
