1 members (Hotrod Lincoln),
55
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | OK, my valve cover it painted and dry. You can see the pics at my Webshots page link below, page 4 or 5 I believe. I would appreciate your feedback as this is my test piece. I used the F#$d gray by Duplicolor in a rattle can. I like the color but would like your honest opinions. Thanks, WADA | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Looks good to me. I'm not a real" ORIGINAL" fan anyway. I love this site cuz they say it's your truck do it the way you want!
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I would prefer that the valve cover be the color of the side cover, its original color and the original color of the entire engine and bellhousing. It is your truck, but you asked for opinions. The work you have done on the truck is excellent. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Wada,
I like that color, nice job. What is the purpose of the 'shunt' stuck in the center oiler overflow tube?
Stuart | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | what color should the valve cover on a 51 3100 be | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | That's a nice paint job, but it is way lighter than the dark gray/blue original color. That looks like a Jim Carter or Bill Hircsh color rather than the correct Chevs of the Forties or Filling Station color. The color on the outside of Wada's unmolested side cover is correct. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Oh, Gee, Baldy, I will have to repaint it! For what it is worth, that is my color, just like the orginial engine!! | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | It's Blue  | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Well guys, from the research I've done, this color will do. I've looked at a lot of pictures and heard that different factories used slightly different variances of the original gray. It doesn't really have much of a blue hint to it, but close enough. The camera picture does look lighter or brighter than it does in person. I appreciate all of your input. Now for the "Thristmaster" emblem application. Will post another pic when applied. Thanks again! WADA | | |
