4 members (MikeStone1953, Wally / Montana, Bill Hanlon, mick53), 88 guests, and 5 robots.
Topics128,181
Posts1,057,184
Members48,465
1 Offline
Im installing a 87 C10 tilt column and booster/master cylinder pedal assambly in my 51 3100 and im having problems, the pedal shaft is rubbing the column,I ran the column thru the same opening as the old column and installed the pedal assambly bracket in place of the old dash bracket, has anyone ever done this before if so do you have any pictures or know of any ? I cant figure this out ! HELP
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Do you have pictures of this?
~Jim
1 Offline
Not yet , but if i can figure this out I will,
Lol cool
The hole in the floor is offset to the divit in the dash, thats probly why its hitting. When i put my colum in i moved the hole in the floor about an inch to the drivers door.
1 Offline
52motorhead
Did you have any problems with the wiring on the ignition switch hitting the pedal shaft ? it looks real close
Todd
NO problems with mine. I used a tilt colum from a 83 firebird and the master/booster/pedal assembly from a 84 s-10. Fits like a dream
