| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | My '58 3/4 ton has the same e-brake lever as my '59 1/2 ton, under the dash, left of steering column. I looked at what I was told was a '59 3/4 tom that was for sale (the metal tags with GVW and VIN were not readable). The e-brake lever was on the right of the gear shift lever. Is this correct with a 3/4 ton in '59 or is this truck most likely actually a 1 ton??
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | do the fender spears say 36 or 38? is the WB 123 or 135? there was a range of GVWs possible, and with the double [overload] spring pak in back it could be a heavy duty 3600 if 123" WB, but would be a 3800 if 135"
the under dash brake was standard on either a 3 or 4spd, but the floor mounted brake would only be on a 4spd, and that may have been an option on a 3600
Bill | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Not sure how it works with the later trucks, but it's my experience with the '41 thru '53 trucks that there is little difference between the 3/4 ton and 1 ton trucks in regards to location of the eBrake lever or other largely 'cosmetic' things.
From a quick glance at the TechTips section here on the bolt, it looks like in '58 and '59 they only made one kind of 1 ton truck.. it had a 135" wheel base.
If the VIN/Serial number is unreadable, that might be your only real clue.. but i'm sure somebody with a lot more knowledge in that area will be along with more helpful hints.
| | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | More than one 58 one tone was made. Dually vs. not.
Maybe your e-brake lever is under the dash because you have an automatic tranny not the 4 speed manual. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Carl,the 4 speed with E-brake could have come from a big truck,like a 1-1/2 or 2 ton. Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
