0 members (), 52 guests, and 1 robot.
Topics128,132
Posts1,056,730
Members48,454
My '58 3/4 ton has the same e-brake lever as my '59 1/2 ton, under the dash, left of steering column. I looked at what I was told was a '59 3/4 tom that was for sale (the metal tags with GVW and VIN were not readable). The e-brake lever was on the right of the gear shift lever. Is this correct with a 3/4 ton in '59 or is this truck most likely actually a 1 ton??
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
do the fender spears say 36 or 38? is the WB 123 or 135? there was a range of GVWs possible, and with the double [overload] spring pak in back it could be a heavy duty 3600 if 123" WB, but would be a 3800 if 135"
the under dash brake was standard on either a 3 or 4spd, but the floor mounted brake would only be on a 4spd, and that may have been an option on a 3600
Not sure how it works with the later trucks, but it's my experience with the '41 thru '53 trucks that there is little difference between the 3/4 ton and 1 ton trucks in regards to location of the eBrake lever or other largely 'cosmetic' things.
From a quick glance at the TechTips section here on the bolt, it looks like in '58 and '59 they only made one kind of 1 ton truck.. it had a 135" wheel base.
If the VIN/Serial number is unreadable, that might be your only real clue.. but i'm sure somebody with a lot more knowledge in that area will be along with more helpful hints.
More than one 58 one tone was made. Dually vs. not.
Maybe your e-brake lever is under the dash because you have an automatic tranny not the 4 speed manual.
Carl,the 4 speed with E-brake could have come from a big truck,like a 1-1/2 or 2 ton.
Floyd
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
