| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 12 | I have a 41 GMC 1/2 ton with a 228 c.u six. has anyone changed to a two barrel card on this engine? What did you use? how does it work? | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion....give Tom Langdon of Stovebolt Engine Company a call...he's knowledgeable about the early GM's....I used his Holley/Weber progressive 2 bbl on my 54-235 and find it gives me improved performance, mileage, and ZERO problems, right out of the box.
The cost is in line with a rebuilt 1 bbl with none of the pitfalls. Give him a call.
Hope this helps. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You could bolt on a GMC 302 manifold- those used a Holley AA-1 two bbl carb. You just need to modify the port alignment rings to center it- the ports are a bit larger on the 302's head.
