5 members (Phak1, Gray_Ghost, NJC, Otto Skorzeny, UtahYork), 102 guests, and 1 robot.
Topics128,057
Posts1,055,810
#225852 01/29/2007 2:45 AM
I have a 41 GMC 1/2 ton with a 228 c.u six. has anyone changed to a two barrel card on this engine? What did you use? how does it work?
#225853 01/29/2007 4:04 AM
Just a suggestion....give Tom Langdon of Stovebolt Engine Company a call...he's knowledgeable about the early GM's....I used his Holley/Weber progressive 2 bbl on my 54-235 and find it gives me improved performance, mileage, and ZERO problems, right out of the box.
The cost is in line with a rebuilt 1 bbl with none of the pitfalls. Give him a call.
Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#225854 01/29/2007 5:07 AM
You could bolt on a GMC 302 manifold- those used a Holley AA-1 two bbl carb. You just need to modify the port alignment rings to center it- the ports are a bit larger on the 302's head.
Paint & Body Shop moderator
