| | | Forums66 Topics128,151 Posts1,057,001 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Will a tailgate from 47 to 53 fit a 42 box? | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | hmmm....good question, let me check around and see.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | No. The '41 thru '46 box is a little more narrow, but you can pull the ends off, trim each side down, and weld the ends back on and it looks pretty good. That's what I did with my 46 1/2 ton. [img] http://oldtruckstuff.com/mytrucks/rear_wood_on.gif[/img] Well.. had my brother in law welder guy do it for me, anyway.
| | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Thanks for the quick response. Your tailgate looks good. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Thanks.
When I got that truck, the original tailgate looked like hell.. but i'd seen several '41 thru '46 1/2 ton trucks with the later '47 thru '53 tailgates on 'em, so I figured they outta fit.
So I pulled one off one of my parts trucks, and lo and behold, it was too wide.
Then I got to looking at some of the '41 thru '46 trucks i'd seen with the 'AD' tailgate and saw that most of them had not only the AD tailgate on 'em, but also the AD BED.
I'm not sure what all is involved in that, but i've seen several 'Deco' trucks with 'Advance Design' beds and rear fenders on 'em. I guess they must be easier to find.. but they don't look bad, and at a casual glance, I doubt most folks would even notice.
| | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | wow, that does look nice. I wasnt finding much in my search anyway.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'm pretty sure all the 'factory' tailgates on the '41 thru '46 pickups were either blank, or had some strange looking script style Chevrolet written across the back. I personally like the way the '47 thru '53 tailgate looks on the back of a 'deco' truck, and at the same time it doesn't stick out like a sore thumb to anyone but the most anal retentive purist who would be quick to point out, "That ain't the right tailgate on that truck!!" John Deere Green probably wasn't a 'factory' color in 1946, either.. nor was putting the paint on with a brush.
