6 members (Otto Skorzeny, MikeE, Hotrod Lincoln, ShopRag, TooMany2count, J Lucas), 32 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#225592 01/24/2007 12:46 AM
Junior Member
Junior Member
Hi, I am new here and wondering if anyone can tell me where I can find a shifter bracket for a 3spd column shifter on my 55 1st. The old one (had) threads and I called chevy duty because they had one in ther catalog but said that it only fits up to 53's and they couldnt even tell me where I could find one. By the way I have already exhausted all the scrap yards"malls" around me. Any info would be appreciated.
#225593 01/24/2007 7:46 AM
Hi Cheap,
Welcome to the bolt! You should post this in the swap meet section under parts wanted. That is where you'll have the best luck!
Glad to have you as a part of the site...enjo!
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#225594 01/24/2007 9:34 PM
Junior Member
Junior Member
ok thanks.
#225595 01/25/2007 6:16 PM
cheap 55, if you could explain exactly what it is and if one off of a 54 would work i may be able to help. btw i have chevy duty catalog and i see what they say it is, i will look in my shop later and see what i have. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#225596 01/26/2007 12:21 AM
A little more info or a picture of what you're looking for. I have the lower box assembly from a 54 column shift that will go into the scrap if nobody wants it. Let me know and I can get you a picture to varify it is what you need.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#225597 01/26/2007 10:08 PM
Junior Member
Junior Member
I went ahead and ordered the one through chevy duty to see if it will fit, I believe it will, should have it in a couple of days. I would post a pic but camaras down, thanks all.
#225598 03/17/2007 1:02 AM
Apprentice
Apprentice
Hey... did the Chevy Duty part fit your truck? The threads on my shifting bracket are stripped and it's causing me all sorts of shifting problems, so I either need to find a way to repair it or get a new one. Any suggestions?
My mechanic calls it an oil leak... I call it my truck's 'self-lubricating chassis' feature.
#225599 03/17/2007 8:50 PM
Apprentice
Apprentice
