| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 3 Junior Member | | Junior Member Joined: Jan 2007 Posts: 3 | Hi, I am new here and wondering if anyone can tell me where I can find a shifter bracket for a 3spd column shifter on my 55 1st. The old one (had) threads and I called chevy duty because they had one in ther catalog but said that it only fits up to 53's and they couldnt even tell me where I could find one. By the way I have already exhausted all the scrap yards"malls" around me. Any info would be appreciated. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hi Cheap,
Welcome to the bolt! You should post this in the swap meet section under parts wanted. That is where you'll have the best luck!
Glad to have you as a part of the site...enjo! | | | | | Joined: Jan 2007 Posts: 3 Junior Member | | Junior Member Joined: Jan 2007 Posts: 3 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | cheap 55, if you could explain exactly what it is and if one off of a 54 would work i may be able to help. btw i have chevy duty catalog and i see what they say it is, i will look in my shop later and see what i have. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | A little more info or a picture of what you're looking for. I have the lower box assembly from a 54 column shift that will go into the scrap if nobody wants it. Let me know and I can get you a picture to varify it is what you need.
Dave | | | | | Joined: Jan 2007 Posts: 3 Junior Member | | Junior Member Joined: Jan 2007 Posts: 3 | I went ahead and ordered the one through chevy duty to see if it will fit, I believe it will, should have it in a couple of days. I would post a pic but camaras down, thanks all. | | | | | Joined: Oct 2006 Posts: 29 Apprentice | | Apprentice Joined: Oct 2006 Posts: 29 | Hey... did the Chevy Duty part fit your truck? The threads on my shifting bracket are stripped and it's causing me all sorts of shifting problems, so I either need to find a way to repair it or get a new one. Any suggestions?
My mechanic calls it an oil leak... I call it my truck's 'self-lubricating chassis' feature.
