1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#225572 01/24/2007 11:17 PM
On our '53 bolt, we are trying to install the new laminated corner glass that we got for many bux from Chevsoftheforties. We ordered the channel and the rubber, and now have almost absolutely no room for the glass! We have used silicone and still no good.
Has anyone had any experience with this knotty problem?
#225573 01/25/2007 4:09 AM
Yes, took it to a pro and he put it right in. There are several tricks to the job and we felt like it was above our heads to try to save $ and take a chance on breaking the glass. Good luck!
#225574 01/25/2007 4:18 AM
First off,,the orig. glass was NOT laminated. It was solid tempered. It'll take a beating before it breaks. Secondly, i've been the route with the repro rubber for the corner windows,almost hadda start therapy!!!!
If theres any way you can re-use your old rubber,,do it.
Marty
#225575 01/25/2007 5:20 AM
I had a pro do the corner windows. He charged $50 to do the corner windows. We fought with them the first time we did our resto. Best $50 bucks I spent on our 53 yet. He charged $100 to do the whole job. Front and rear windows included. We used repo rubber all around.
#225576 01/25/2007 6:06 AM
The corner glass is the only glass that I
didn't replace, but I did install new repo seals
on the corners...really didn't find it too difficult. Just don't forget to use soap.. Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#225577 01/25/2007 5:27 PM
Let a glass co. do it. If you don't have a fiber stick you will break it for sure.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#225578 01/25/2007 9:23 PM
I installed mine but it was tricky.Heat the rubber in a pail of hot soapy water and take your time.Curse at it enough and it will go in.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#225579 01/26/2007 12:08 AM
Bill and Wilbur mentioned the two keys to getting the windows in with ease. When I reinstalled the corners in my 54 I used a squirt bottle with a strong dish soap solution. The rubber needed to be "massaged" so I took an old toothbrush, cut off the end, touched it to the disc sander to put an angle on the end. About the same as a fat straight-slot screwdriver. You can lift the rubber without scuffing your paint.
BTW...This little home-made tool has gotten a workout during the entire rebuild process. I've noticed Eastwood offers a complete set but I'll stick with ole "Oral-B."
Using this soapy solution, some mechanics gloves for grip and the little tool the windows went in without any problem. Hope this helps!
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
