2 members (Brian Moore, J Lucas), 67 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#225524 01/23/2007 6:00 PM
ANYONE HAVE ANY POINTERS ON BODY DROPPING ? I HAVE A 53 3100 WITH A 350, AUTO TRANS, GOING TO ATTEMP A BODY DROP ! THANKS FOR ANY HELP !!
#225525 01/23/2007 10:53 PM
I asked a similar question a while back and someone suggested I fill the truck full of concrete until it lowered to the desired height.
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
#225526 01/24/2007 5:09 PM
NOT SURE IF ANY OPF YOU READ "OL SKOOL RODS" BUT THIS MONTHS ISSUE HAS THE COVER STORY BEHIND MY IDEA FOR THE BODY DROP.... YOU CANT GET THIS LOW WITH A SIMPLE SUSPENSION DROP ! TRUST ME !
#225527 01/24/2007 10:38 PM
TURNING THE WHEELS WON'T BE A PROBLEM. NO FENDERS NO PROBLEM !
#225528 01/24/2007 10:40 PM
OH AND NO RUNNING BOARDS !
#225529 01/24/2007 10:47 PM
Bige, you might check out this link
click here
my truck is lowered with their stuff.. I plan on driving it to the Ft.Worth meet Sat,so you can take a look.. several other bolters will also be there.. hope you can make it.. check out the event section
Fred
Redryder pix
My Hotrod
#225530 01/24/2007 11:11 PM
LOOK AT THE MOST RECENT COPY OF --OL SKOOL RODS --, AVAILABLE AT ANY BARNES AND NOBLE OR WALDEN BOOKS... WILL USE AN OLD SCHOOL GRILLE FROM A 30'S TRUCK OR CAR, AND OLD SCHOOL HEADLIGHTS ... AND AS FAR AS TEXAS NOT ALLOWING HAVING NO FENDERS, ITS ALWAYS BETTER TO ASK FORGIVENESS RATHER THAN PERMISSION ! THATS MY MOTTO ! LOL THIS WILL BE A ROD NOT A "SHOW TRUCK " OR FRAME UP RESTORE..
#225531 01/24/2007 11:52 PM
YES, CORRECT ON THE ISSUE # ROBIN,,,, I'M ONLY GOING TO CHANNEL IT 6" THOUGH AND NO CHOPPING WILL OCCUR, AND I ALREADY HAVE REMOVED THE COLUMN AND WAS GOING TO HAVE IN CUT ACCORDINGLY .. APPRECIATE THE INFO,, THATS THE FEEDBACK I WAS LOOKING FOR TO BE SURE I'VE COVERED MY BASES, YA KNOW. I WILL LOWER THE REAR 4" AND THE FRONT AROUND 2", ITS ALREADY GONNA BE AN UNCOMFORTABLE RIDE, BUT IT WILL JUST BE A SPRING, SUMMER WEEKENDER FOR ME AND MY PERSONAL PIN-UP ! THANKS AGAIN !!
#225532 01/25/2007 7:00 AM
why channel the body the frame is plenty tall you can take 2 inches off the top of it and box it under the cab so you dont have to channel the body, and kick the frame up in front of the cab and in the rear of the cab
1949 SUBURBAN
#225533 01/25/2007 7:21 AM
robin58--you are correct sir. I was just trying to be funny and maybe a little bit sarcastic too.
I'm still in the thinking stage of my body drop.
Toxictiki
#225534 01/25/2007 2:53 PM
I'D RATHER KEEP THE FRAME STOCK IN CASE I SELL IT TO AN ENTHUSIAST . I'D RATHER CHOP UP THE FLOOR BOARD, I THINK THATS INEVITABLE ANYWAYS IF YOUR GOING TO DO ANY TYPE OF CUSTOMIZING ON THESE DINOSAURS .... THE FLOORS ARE ALWAYS RUSTED OUT LOL. I HAVE 3 56' CHRYSLER IMPERIALS TOO AND ONLY ONE DIDN'T HAVE A RUSTED OUT FLOOR, BECAUSE IT WAS IN MY GRANDFATHERS BARN FOR 30 YEARS.
#225535 01/25/2007 10:02 PM
Bige.. Sounds like an interesting project. A little different than what most around here are doing, but it's your truck. smile I'm looking forward to seeing how it turns out.
BTW.. I know they do things BIG in Texass, but could you stop shouting in your posts. My ears are hurting.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
#225536 01/26/2007 6:08 AM
Here's a picture of a 63 with a 5" channel and stock suspension. http://s32.photobucket.com/albums/d41/coilover/ It has a flat floor so is similar to yours Five inches was chosen with the driver sitting in the seat and allowing comfortable head to top spacing. Be aware that everything mounted to the firewall/dash that has a certain spacing will change when the floor stays put and the cab is lowered. This includes the brake/clutch pedal assembly, accel bracket and pedal, steering column, etc. Of course the bed and core support must be repositioned so the front sheetmetal and bed match the lowered cab body lines. Channeling is not used as much as in the past because it's very labor intensive and so many suspension options are available to give one just about any stance.
Evan
#225537 01/26/2007 7:28 AM
Junior Member
Junior Member
Check out this site.
http://www.killbillet.com/index.php
Its all here with pictures.
#225538 01/26/2007 3:11 PM
sorry about the yellin guys, i hate small text lol , thanks for the links also ya'll !! i am rethinking, the channel though, the wife is against it, prolly just gonna susp. lower it a little and still rat rod it a little lol still thinking it over !!! thanks for all the wisdom !
