7 members (Jon G, TUTS 59, 68ironhead, Joe H, Maybellene, HandyAndy, carbking), 70 guests, and 2 robots.
Topics128,049
Posts1,055,747
#225480 01/23/2007 4:46 AM
hello, folks. i have a 1952 3100 chevy that i am wanting to make an ole school truck . i want it like one would have been hot rodded in the 50,s and 60,s. i want to leave the drive train original.
i have the hop up items for the engine, a visor, 8" STEEL WHEELS, and a few other items.
now what do i do about the shifter? did they or do they make a floor shift kit for the torque tube 3 speeds.
any other ideas from the 50,s and 60,s would be helpful.
http://www.flickr.com/photos/11977495@N06/sets/
1952 COE
1952 3100
1953 3100
1950 6400
1951 Suburban
#225481 01/23/2007 4:55 AM
Check Mr. Gasket products. I have a floor shifter for my 1955 ...they are year specific so make sure you are looking at the right one both for cars or truck...Steve ps also check search on this site as there is a lot of information on this subject.
#225482 01/23/2007 5:48 AM
I'd guess an old school 3100 hot rod would involve a rear end out of a passenger car, probably a tranny out of something else besides a truck, and probably dual carbs.
Those factory 3 on the tree torque tube trannys are dogs, man.. and having busted two of 'em already (one in a '46, and one on a '50) i'm of the opinion that the torque tube design sucks hairy, sweaty, tick infested moose balls.
#225483 01/23/2007 6:15 AM
Anson made a floor shift conversion back in the 50's. I had one on a '57 Chev. You might try a search on e-bay, there were a lot of them around.
#225484 01/23/2007 5:37 PM
What's wrong with the column shift? If you want to keep originality leave it there.
Curt B.
You Tube
#225485 01/23/2007 6:01 PM
Fumblin46,
Is that type of moose indigenous only to western Nebraska? wink
Stuart
#225486 01/23/2007 6:31 PM
check with this link
he can fix you up with all that you need, change your transmission to a four speed, 3:55 ring and pinion, the whole works and keep your enclose drive shaft.........they have a lot of speed equipment.. give them a call, he will be glad to answer any and all questions...
Redryder pix
My Hotrod
