4 members (Wally / Montana, tclederman, Donf, cmayna), 91 guests, and 2 robots.
Topics128,086
Posts1,056,101
Members48,434
#225291 01/21/2007 8:21 PM
Has anybody ever had a gas tank steam cleaned? I have a friend in town here (yes I have a friend!) who had a tank from a 1937 Chevrolet steam cleaned. He said it's just like new and was told it would NOT need to be coated. Any thoughts on this? :confused:
My Trucks
Stuff I Collect
#225292 01/21/2007 8:37 PM
Ex Hall Monitor
Ex Hall Monitor
Never heard of it. The 37 tank should have baffles in it that would make it difficult to clean the whole thing without making access holes in the tank. While it may look good where you can see I'd be suspect of it being clean throughout. I'd like to have more details about the process if you can get them. Maybe a web site to check out?
#225293 01/21/2007 8:46 PM
Hot (hot, hot water) water and Red Devil Lye will clean a tank like new. It neutralizes rust and turns it into a black carbon looking slime which can be rinsed off as well.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
#225294 01/21/2007 8:54 PM
Ex Hall Monitor
Ex Hall Monitor
The problem being that once a protective layer has been breached and rust has started you can "clean" it but if you don't protect the metal it will rust again. Keeping the gas tank as full as you can will not stop rust. As you use gas it pulls moisture laden air into the tank.
#225295 01/21/2007 9:18 PM
I had my tank steam cleaned after truck sat dormant for more than 10 years. I was amazed at the difference it made in the way the truck started and ran. I had previously drained and refilled the tank thinking that good enough but the stale fuel varnish was worse than I would have thought. I have the stock behind the seat tank and there are no baffles in it. I am a believer in the process. Again, The shop used steam only on mine.
