7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna),
140
Mod | | | Forums66 Topics128,204 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 18 New Guy | | New Guy Joined: Jan 2005 Posts: 18 | I want to raise the rear of my 51 GMC longbox between 2-3 inches. currently sits low compared to front end.
if main leaf is #1 and OK, how much lift could I expect if leafs 2 and 3 were replaced with new ones. Anybody got any experience on this??
I have access to a couple reputable spring joints near me, and one guy said this would do what i want. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Are leafs 2 and 3 bad? The spring shop should be able to re-arch those to original height. | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | I had the same problem. Since I had the 3200 series with spring helpers, I just disassembled the leaves and stacked in the extras. However, I finally reached the point where that didn't work after adding a rear fuel tank, which (full) drags the rear end even lower. I ended up installing air shocks in the rear. | | |
