Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (2-Ton, Hanks custodian), 132 guests, and 4 robots.
Topics128,291
Posts1,058,585
Members48,492
I want to raise the rear of my 51 GMC longbox between 2-3 inches. currently sits low compared to front end.
if main leaf is #1 and OK, how much lift could I expect if leafs 2 and 3 were replaced with new ones. Anybody got any experience on this??
I have access to a couple reputable spring joints near me, and one guy said this would do what i want.
Are leafs 2 and 3 bad? The spring shop should be able to re-arch those to original height.
I had the same problem. Since I had the 3200 series with spring helpers, I just disassembled the leaves and stacked in the extras. However, I finally reached the point where that didn't work after adding a rear fuel tank, which (full) drags the rear end even lower. I ended up installing air shocks in the rear.
