2 members (Otto Skorzeny, 1 invisible),
97
7
Mod | | | Forums66 Topics128,181 Posts1,057,189 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | When I removed my old transmission the converter was held onto my flywheel with a nut and bolt. My new stall converter has fine threads in it. I ran a bolt thru my flywheel into the threads on my converter. It tightened up real, real tight. Now that the motor is back I am thinking if I should add a nut to that bolt. What have you guys done?
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Now that the motor is back in my truck is what I meny to say!!
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | rogpatt,
It isn't a normal procedure to add a nut when the fastener is threaded through a piece. The SOP would be to include a lockwasher, or some type of locking compound the the bolt or screw.
It sounds like you are nervous about this. Not every situation calls for a lockwasher, although the flexplate to converter connections I can think of did use them.
If this is going to bug you, and there is ANY access to the area, you could put a drop of 'post assembly' Loctite on the threaded protrusion of the bolt.
Stuart | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Yes I am a bit nervous about this! I figuered that I did not have to add a nut but I am not a transmission expert so I was not 100% sure. Thanks for you response!
Roger
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | A drop of blue Locktite will do fine.As mentioned, if you can get at the end of the bolts,put a drop on them.If you can back the bolts out,put some on the threads and run it back in. | | |
