5 members (JoergK., cmayna, Otto Skorzeny, TexasJim50, Opelika Tom), 92 guests, and 6 robots.
Topics128,185
Posts1,057,205
Members48,465
Junior Member
Junior Member
Hi there. I have recently been gifted with a 51 Chevy pickup. no engine or tranny and in pieces of course. i have done a search but can't seem to figure out why the rear wheels are 6 lug and the front a 5 lug. any ideas. I would like to figure out what i have before i try to figure out where to take it.
thanks
Greg
Welcome to the Stovebolt!
Originally both the front and rear were six lugs. Someone has changed the front to five. There are several ways that might be done and it would take more information to know which...
Does it have drum brakes or disks brakes on the front? Does it have leaf or coil springs in the front?
welcome to the shop Greg - lookin around here for awhile will fill in the blank spots for ya!
sounds like someone changed someting in the front - if it's still the original straight axle, then prolly the front hubs and drums from a 50's car were installed, not unusual when folks want to run fancy rims, which aren't as available in the 6bolt pattern - the 6 lug back axle will be original
Junior Member
Junior Member
drums brakes with leaf springs.
thanks for the welcome
I would guess that someone replaced the front hub assembly with one off a car of about the same vintage.
Fred
52 3600
69 C-10
Fred is right.
Check the brakes, backing plates and the front bearings really carefully. This is a common modification but if not done right it may be unsafe.
Hubs and drums from an early 50's Chevy car is typical and results in a 5 x 4-3/4 bolt pattern. But the same approach can put larger drums from a Pontiac, Buick or Olds of that some era so your pattern could be 5 x 5 or even something else.
The same approach can be used to put 5-lug disk brakes on the front of one of these trucks and there are kits with parts and instructions.
