Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 136 guests, and 10 robots.
Topics128,281
Posts1,058,470
Members48,490
Hi all, new to the site, I have a question on window glass patterns for a 51. I have a local man that cuts glass for hotrods but he doesn't have the pattern for a 51,I tried the search and I coundln't find anything on it. I'm not that computor savy,anyways, does anyone have a pattern for this or can lead me in the rite direction. I put my 51 on a s-10 frame, if I can figure this out I will post some pictures,thanks in advance for your help. Dan
Hi Dan and welcome to the bolt. I don't have any patterns for the 51, but all my glass is out of the truck. If you would want to take measurments and make patterns we should get together. I am only 45 minutes south of you.By the way,you wouldn't still have your original gas tank would you?
Elm,
If he doesn't, I do. Not all that far from you.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
Elm, thanks, I believe I still have my gas tank, it might take a bit too find it. I also have a bed I think came from a 54,I was going to put it on ebay but I'm going to offer it on this site first, would like to help someone out if I can. we should get in contact I can bring the tank and we'll measure up the windows.
51dan79 check your Private Messages.
pablos, we need to get together when the weather gets little better. let's get through this cold spell and maybe get together on some weekend.
Sounds like a good idea. Once I get my truck out for the summer, I'll feel like going on a little drive. Like I said, if 51dan79 doesn't have a gas tank, I've got one on my shelf in the garage.
I don't really need the tank, I need the main gas shutoff valve and the sending for a 1951 Chevy. Both were missing when I got my truck.I am trying to put it back together as original as possible. Let me know if you have them and I will send you an e-mail. thanks
elm, I might have a sending unit in my boxes out there. I'll take alook tomorrow and let you know.
Elm, i have the valve you need I'll lok for the rest later
Thanks Dan. I will try to catch up with after this snow storm. I thought we were only supposed to get flurries. Yeh right. They say we could get up to 8 inches now. If you have time could you check and see if you have the parking brake swing arm and pedal assembly out of the 51?
i need a 51 tank and sending unit, do you want to sell it? how much?
you also might think about this idea
an in your tank primary filter
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00312.jpg
Jim & Caroline
