| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | I'm removing my master cylinder to rebuild it and I can't get the brake pedal off. How does the pin through the master cylinder and pedal arm come out? Should it just slide out after the retainer is removed? I tapped on it a little and it didn't move. Should it come out toward the frame or the transmission? I guess I want to make sure that if I pound on it, that I'm pounding in the right direction. HELP PLEASE!
Thanks, Andy | | | | | Joined: Oct 2006 Posts: 15 Apprentice | | Apprentice Joined: Oct 2006 Posts: 15 | Just looked at mine (55 second series) - it comes out toward the fram on mine. The pin is accentric, so it might pay to mark the position before you start pounding.
good luck Pete | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's actually 3 points to unbolt - the one you need to remove is the "upper pedal" to free the part that goes thru the floor from above, the rest can stay on the mstr cyl util you get it out - see pic at bottom of this page that the main one right below the floor you'll need to leave the nut on and use a BFH on it or turn the pedal arm above with a pipe wrench - the eccentric one is usually siezed [called "adjusting bolt"] from fluid dripping on it - the "lower arm" right at the mstr has the keeper plate, doesn't even need to come off unless you actually replace the mstr Bill | | |
