0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | What's the best product or method for removing the muddy grease on items like the oil pan, frame, and rear axle? I have tried Gunk engine brite degreaser, but it doesn't work that well. Is there something that can be sprayed on and then powerwashed off? I have tried oven cleaner on other things in the past. It removes grease and paint, but tends to rust badly if nothing is done immediately after washing it off. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Anything that removes grease is going to cause rust after it comes off, because the grease is whats keeping the metal from rusting.
You can always fog the bare metal with WD-40 after you clean it, in fact WD-40 also tends to remove grease without harming paint.
I like Gunk or Simple Green. If you hook your hose up to hot water it works a bit better.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I use gasoline and a parts cleaning brush. Then blast it with the hose. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Brake cleaner works.Expensive but works well | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I usually use a couple cans of spray degreaser, then simple green... take it to a spray and wash place, if you can find one that allows that sort of stuff.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Get you a 55 gal barrel, fill it (40 gal) with hot water and add about 200 oz. of lye. Heat the barrel with a wood fire or propane heater under it. Heating speeds up the lye's work. The lye solution works equally well removing paint. The large barrel will allow you to strip a lot of larger parts.
~Jim
| | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Marine Degreaser works better than the Engine Brite/Gunk spray can stuff. Based on what it does to your skin and what it does to grease, I'm betting it is a strong caustic solution like lye dissolved in water.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | |
