7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22358 02/15/2004 3:55 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Getting ready to install my new brake system (new SS lines and cylinders). What is the suggested brake fluid? Whats the difference between Dot 3, 4 and 5?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#22359 02/15/2004 4:26 PM | Joined: May 2001 Posts: 9 Junior Member | | Junior Member Joined: May 2001 Posts: 9 | DOT3 (&4) are glycol-based, while DOT5 is silicone-based.
In theory, DOT5 is superior to anything else as it has a higher boiling point and doesn't attract moisture, but for the life of me I have never had luck with the stuff. It seems to hold air which leads to spongy brakes and your system has to be totally rid of the old fluid as the two aren't compatible.
Valvoline Synpower makes a DOT4 that I can recommend. I wasn't satisfied with the brake performance in my '51, so I flushed out the DOT5 and replaced it with the Synpower DOT4 and all my problems went away. | | |
#22360 02/15/2004 7:14 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it's a daily driver, go with dot4. If it's only driven to church (I know how often most of us go) use dot5.
Fred 52 3600 69 C-10
#22361 02/15/2004 8:31 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |  Because of the high quality of restoration you are doing to your truck, Craig, I highly recommend DOT 5 Silicone. If you use regular Dot 3 or 4, you will put all of your paint restoration work at risk. Dot 3 or 4 will destroy your paint work no matter how careful you try to be. Dot 5 Silicone will not phase your paint work and be your best choice for all the other reasons. The only thing about Dot 5 that I have found to be a problem is leakage. It is so thin and slick that if your are going to have a leak in your system, it will show up with Dot 5 Silicone. Since you are totally rebuilding your system, that may not be a problem for you. I would take that chance. As far as bleeding the air pockets out of it - yes, it does take longer to do that, but you can get them out. Patcience is the key! I know you have patience by what I see you are doing to your truck! I have had it in my 37 since 1980 and have enjoyed all of the positive aspects of Dot 5 Silicone. One last comment - it is expensive with a quart going for about $30.00.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#22362 02/18/2004 5:34 AM | Joined: Jun 2001 Posts: 11 Junior Member | | Junior Member Joined: Jun 2001 Posts: 11 | If you are starting out with clean lines and cylinders, use Dot 5.
I use it in my '54 3100, works fine. | | |
#22363 02/18/2004 7:52 AM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | For those with original (vintage) master cylinders, DOT3. The newer stuff can harm the older rubber seals and cause leaks.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#22364 02/18/2004 10:05 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I use DOT3 or DOT4. Dot 4 is more hydroscopic than Dot3 (attracts water easier) but has a higher boiling point. Both Dot3 and dot 4 have a significantly lower boiling point when they are saturated with water, and should be changed annually since the stovebolt system is an open system. A system with a more modern master cylinder with a bellows breather can handle changes every two years. I change my fluid every 3 times I adjust the Hucks. Always change fluid anytime you open the system. I change it by cracking the far bleeder and topping it off as it bleeds down, and then re-bleed all four corners until it runs clear. That gets 99% of the water and crud out.
#22365 02/18/2004 2:03 PM | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | When I rebuilt my brake system I used Dot 5 and had trbl with leaks. I flushed out the Dot 5 and replaced it with Dot 3 and had no trbl. with leaks since.
'52 Chevy 5 window, it ran when I parked it '53 Chevy 5 window, running the streets with me. '55 Massey-Ferguson, tearing up the dirt '89 Harley FXSTS, suicide clutch '92 Harley FLSTC, equal time with the '89
