3 members (Otto Skorzeny, dt235sd, Rusted Nut), 80 guests, and 2 robots.
Topics128,048
Posts1,055,664
#223588 01/06/2007 12:04 AM
1 Offline
Im looking for ideals on moving my gas tank from behind the seat to a new tank between the frame rails under the bed any info on vendors or a donner gas tank from another truck/car that will work ?
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
...on 39-53 pickups, 68-72 Nova or clones as well as 67-9 Camaro/Firebird tanks fit real nice, are available repro at good prices, and fill in the rear thru the rear bed sill/ This can be hid with a flip down cover or licence plate.
1 Offline
the truck is a 1951 3100 Thanks I'll look into it how hard do you think is is to install a intank fuel pump for TBI
1 Offline
Sounds Great !! where did the fill neck mount ? and where and how much on the frame do you have to trim ? between the tank and rails ?
Todd
#223593 01/07/2007 11:39 PM
1 Offline
Just left the junkyard and checked out a 1991 blazer 31 gallon tank with the intank fuel pump that I think will work fine
Todd
#223594 01/07/2007 11:47 PM
1 Offline
Also the 68 thru 72 nova gas tank will work good to "thanks acmegarage" and can be converted to the in tank setup easy " with a 1990 1500 chevy pickup fuel sender assambly"
I am looking to relocate the gas tank as well. However I'm not too excited about having a filler in the bed and not experienced enough in bodywork to run it out the rear fender. The idea to put the filler behind the license plate sounds like something even I could do. Does anyone have pictures of this process?
~Jim
