1 members (RoseB), 109 guests, and 3 robots.
Topics128,195
Posts1,057,374
Members48,469
#22353 09/01/2002 10:28 PM
I am installing a trans cooler on my Turbo 350 auto. Trans, and I need to know if the upper or lower Trans line is the return line?
There are two outlets on the side of thhe transmission, an upper and a lower?
Someone has to know this ???????? Please - Thanks! [img]http://www.stovebolt.com/bboard/ubb//confused.gif[/img]
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
I have always hooked the top line from the tranny to the top on the cooler and the bottom line from the tranny to the bottom on the cooler.I bypass the radiator completely.Heat is the transmissions enemy.Bypassing the cooler in the radiator also allows the engine cooling system to cool the engine better cool
I agree with mechainiac, give your tranny a real chance to cool. Give some thought as to where you are going to place your cooler also. Blocking the radiator further may not be in your trucks best interest.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
